Operate day or night, operate within two zones, stay bright, stay illuminated – go Swiss!
This is the latest DayNight Recon watch from DEEP BLUE – the DayNight Recon GMT Swiss
Automatic Tritium T-100!
It’s all in the name – the spec. that is. The watch gets a Swiss made ETA 2893-2 automatic movement allowing for dual time zones.
The 21 jewel movement has a beat-rate of 28,800 vph and like most DB Swiss models is equipped with a custom DB decorated rotor.
This can be viewed through the watch’s Sapphire exhibition case-back.
As a T-100 model this DayNight Recon GMT is equipped with 66 Tritium Tubes – the dial boats 61 tubes while a further 4 can be found on the hands and a single tube is on the diver’s bezel at 12hr.
The watch is based on a 316L Stainless steel case with a diameter of 45mm, a lug-to-lug measurement of 53mm and a height of 16mm.
Diver’s features of the watch include: a Sapphire crystal, screw-down case-back and crown and 120-click unidirectional diver’s bezel with a ceramic inlay and SLN dive-time scale.
Water-resistant is 500 meters. Special features include a wave-pattern dial. The dial can be had in: black, blue, orange or white.
In addition to a 24hr GMT track there a date aperture can be found between 4 & 5H.
Finally the DayNight Recon GMT Swiss comes on a full 22mm Stainless steel diver’s with:
3X micro adjustments, half links, full links, screw in links and a divers Safety Clasp with Push Button Deployant Clasp.
