Following up the partnership between Prometheus Watch Company and OceanicTime on the Prometheus Manta Ray LE we have partnered once again to release the Prometheus Poseidon 3500m OceanicTime Special Limited Edition.
The 3500m Prometheus Poseidon for OceanicTime is an avant-garde diver watch powered by a Swiss Made ETA 2824-2 movement that brings out to reality a full game of contrasts and a distinctive look.
The main case has a black DLC coating while its components, the bezel, caseback, crown and HEV have all been left in steel. Even the screwed-lug pins are in steel, so that all the key-features of the dive watch have been highlighted for our delectation.
The top of the bezel has a Sapphire crystal inlay; on the black timing-ring below, only the white triangular 12hr marker remains; the origins of which date back to the mid-70s, when the special 3H edition of the Blancpain FF was created for the German Naval Combat divers who only required a single luminous marker for timing missions / dives. BTW this will be lumed.
The black of the bezel cuts a clean contrast against the brushed steel of the dial, itself boasting: a matte black hour hand, matte silver minute and seconds hands and polished indexes – all filled with black Super Luminova. Of course some luminosity has been sacrificed to achieve the desired effect.
To reinforce the minimalism of the watch the rehaut has been removed as well as the text in dials coupled with a wider handset (compared to the regular Prometheus Poseidon) reinforcing the watch’s sense of drama and minimalism.
Only the Prometheus logo, the OceanicTime diver icon and a single line of black text with the watch’s water-resistance remain.
In addition to the aesthetic enhancements, the standard movement has been upgraded to a Swiss made ETA 2824-2.
Finally the Poseidon 350ATM OceanicTime SE is presented on a brushed Stainless steel bracelet. A special divers clasp in black DLC signed with the OceanicTime divers icon completes the look.
Technical Details of the Prometheus Poseidon Stainless Steel Black White Bezel 3500m Miyota 9015 Automatic Diver Watch:
- 316L Stainless Steel Case with Black DLC finish
- Silver Color brushed Dial with Swiss Made RC Tritec Black Superluminova lume applied to indexes
- ETA 2824-2 Automatic Movement
- 316L Stainless Bezel unidirectional with 120 clicks with sapphire insert and applied Swiss Made RC Tritec BGW9 lume on triangle
- Custom made 316L solid stainless steel bracelet with diver extension clasp
- Case diameter: 43.00 mm without crown
- Lug to Lug length: 52mm
- Case height: 15.90mm
- Lug width: 22 mm
- Signed screw down crown with OceanicTime logo
- Water resistance: 3500 meters or 350 ATM
- Helium valve a 9 o'clock
- Sapphire glass with anti-reflective coating inside watch
- Watch hands filled with Swiss Made RC Tritec Black Superluminova lume (hours, minutes, seconds)
- Two Years Warranty
