OceanicTime TWCO Sea Rescue Diver TACTICAL
By TLex Introducing the new Sea RESCUE Diver Tactical model in black DLC!
The Sea Rescue Diver series in Orange and Yellow with its so-called 3 minute Radio Silence markers is now also available in a new tactical BLACK!
Its classic divers case is constructed from surgical grade 316L Stainless steel and features a Sapphire crystal with double anti-reflective coating on the inside,
a high quality mechanical movement and is water-resistant to 600m deep (60ATM). It is also equipped with a very solid unidirectional bezel and a large easy to read minute hand.
Further specifications of the TWCO Sea Rescue Diver Tactical Model BLACK include: a Miyota 9015 caliber with a frequency of 28.800bph (4HZ), 24 jewels and a power-reserve of over 42hours The case is in 316L surgical grade Stainless steel with a black DLC coating.
Full divers features include: a unidirectional divers bezel, a Sapphire crystal with double anti-reflective coating on the inside, a screwdown crown with quintuple Viton protection seals -
and caseback with double Viton protection seals allowing for a water-resistance of 600m (60ATM).
Special features include: bead blasted hands and dial with SuperLumiNova.
Measurements are as follows: case diameter 43mm, bezel diameter 44mm, thickness 15.5mm, lug to lug 51mm.
Functions include: a date display, hours, minutes and central second with balance stop (hacking).
The 120 click unidirectional bezel is with 20 minute markers and a luminous dot at the triangle of the bezel insert (0/60minutes). The inner bezel is with 60 minute markers.
